Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Heat an iOpener and apply it to the top edge of the phone for a minute.
Angle an opening pick and firmly press so that it slips under the back cover.
Slide the opening pick along the top edge of the phone to break up the adhesive.
Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
Repeat the iOpener heating and slicing procedures for the remaining three sides.
Once you have cut through the adhesive, slowly peel the back cover away from the frame.
Remove the back cover.
Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Use the point of a spudger to pry up and disconnect the flash connector.
Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
Remove the following T3 screws securing the midframe:
Thirteen 3.1 mm black screws
Four 4.3 mm silver screws
Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
Carefully peel the black graphite layer from the phone.
Remove the two 4.2 mm T3 screws securing the metal bracket adjacent to the battery.
Remove the metal bracket.
Use the point of a spudger to pry up and disconnect the battery pack connector.
Angle and insert an opening pick under the long edge of the battery away from the motherboard side.
Insert a second opening pick along the same battery edge next to the first pick.
Apply firm, constant prying pressure to the picks to release the battery from the frame.
As the battery loosens from the frame, move the picks inward and continue to pry upwards.
Ferramenta utilizada nesse passo:Tesa 61395 Tape$5.99-
Remove the battery.
To help with alignment, connect the battery temporarily to the motherboard before adhering it in place. Disconnect the battery before you continue with re-assembly.
Insert an opening pick underneath the flat flex cable and slide it to free the cable from the frame.
Use the point of a spudger to pry up and disconnect the antenna cable.
De-route the antenna cable from the phone.
Use the flat end of a spudger to pry up and disconnect the accessory module connector.
Peel away the yellow tape covering the display ZIF connector.
Use the flat end of a spudger to gently flip up the ZIF connector lock.
Use a spudger or tweezers to walk the flat cable out of the ZIF connector.
Peel away the yellow tape covering the digitizer ZIF connector.
Use the point of a spudger to flip up the ZIF connector lock.
Use tweezers or a spudger to walk the ribbon cable out of the ZIF connector.
Slide an opening pick underneath the motherboard below the copper shield.
Twist the pick slightly to release the adhesive tape securing the motherboard to the frame.
Lift the motherboard out, making sure it does not catch on any cables.
Remove the motherboard.
Use the flat end of a spudger to pry up and disconnect the front facing camera connector.
Remove and transfer the front facing camera onto the new display frame.
Insert a pointed end of a pair of tweezers into a corner as far down as possible.
Pry very slightly to help loosen the earpiece speaker module.
Repeat the process in the remaining corners.
Continue to pry with the point of a pair of tweezers until the earpiece module feels loose.
Remove the earpiece module and transfer it to the new display frame.
Use the point of a spudger to pry up and remove the speaker grille cover.
Remove and transfer the speaker grille cover onto the new display frame.
Only the LCD screen and digitizer assembly (with frame) should remain.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
6 outras pessoas executaram este guia.
