Introdução
This guide will take you through the delicate process of removing the rear panel of the Motorola Droid.
O que você precisa
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
6 outras pessoas executaram este guia.
