Ir para o conteúdo principal
Motorola Droid RAZR Rear Case Replacement
O que você precisa
  1. Motorola Droid RAZR Rear Case Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Rear Case Replacement: passo 2, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement: passo 2, imagem 2 %32 Motorola Droid RAZR Rear Case Replacement: passo 2, imagem 3 %32
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Rear Case Replacement: passo 3, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement: passo 3, imagem 2 %32 Motorola Droid RAZR Rear Case Replacement: passo 3, imagem 3 %32
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Rear Case Replacement, Battery: passo 4, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement, Battery: passo 4, imagem 2 %32
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Rear Case Replacement: passo 5, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement: passo 5, imagem 2 %32 Motorola Droid RAZR Rear Case Replacement: passo 5, imagem 3 %32
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Rear Case Replacement, Camera Cover: passo 6, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement, Camera Cover: passo 6, imagem 2 %32
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Rear Case Replacement: passo 7, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement: passo 7, imagem 2 %32 Motorola Droid RAZR Rear Case Replacement: passo 7, imagem 3 %32
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
  8. Motorola Droid RAZR Rear Case Replacement, Rear Case: passo 8, imagem 1 %32
    • Remove the six screws securing the rear case to the rest of the phone:
    • three 6.7 mm silver T3 Torx screws at the top,
    • four 4.0 mm gold T3 Torx screws in the middle,
    • and three 4.5 mm black T5 Torx screws at the bottom.
  9. Motorola Droid RAZR Rear Case Replacement: passo 9, imagem 1 %32 Motorola Droid RAZR Rear Case Replacement: passo 9, imagem 2 %32 Motorola Droid RAZR Rear Case Replacement: passo 9, imagem 3 %32
    • Insert a plastic opening tool between the rear case and the motherboard assembly.
    • Work your way down the side of the phone and gently pry the rear case up.
    • Separate the rear case from the motherboard assembly.
Conclusão
3 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
150.476 Reputação
Autoria de 127 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 7,018
