Ir para o conteúdo principal
Motorola Droid RAZR M Headphone Jack Replacement
O que você precisa
  1. Motorola Droid RAZR M Headphone Jack Replacement, Front Assembly: passo 1, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement, Front Assembly: passo 1, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement, Front Assembly: passo 1, imagem 3 %32
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Headphone Jack Replacement: passo 2, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 2, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 2, imagem 3 %32
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Headphone Jack Replacement: passo 3, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 3, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 3, imagem 3 %32
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
  4. Motorola Droid RAZR M Headphone Jack Replacement: passo 4, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 4, imagem 2 %32
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Headphone Jack Replacement: passo 5, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 5, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 5, imagem 3 %32
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Headphone Jack Replacement: passo 6, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 6, imagem 2 %32
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Headphone Jack Replacement: passo 7, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 7, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 7, imagem 3 %32
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Headphone Jack Replacement: passo 8, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 8, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 8, imagem 3 %32
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
  9. Motorola Droid RAZR M Headphone Jack Replacement, Motherboard: passo 9, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement, Motherboard: passo 9, imagem 2 %32
    • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
  10. Motorola Droid RAZR M Headphone Jack Replacement: passo 10, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 10, imagem 2 %32
    • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
  11. Motorola Droid RAZR M Headphone Jack Replacement: passo 11, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 11, imagem 2 %32
    • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
    • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
  12. Motorola Droid RAZR M Headphone Jack Replacement: passo 12, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 12, imagem 2 %32
    • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
  13. Motorola Droid RAZR M Headphone Jack Replacement: passo 13, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 13, imagem 2 %32 Motorola Droid RAZR M Headphone Jack Replacement: passo 13, imagem 3 %32
    • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
    • Use your fingers to gently pull the motherboard down and out of the rear casing.
  14. Motorola Droid RAZR M Headphone Jack Replacement, Headphone Jack: passo 14, imagem 1 %32 Motorola Droid RAZR M Headphone Jack Replacement, Headphone Jack: passo 14, imagem 2 %32
    • Wedge the plastic opening tool between the front-facing camera’s casing and the rear assembly. Pry until the camera snaps off.
  15. Motorola Droid RAZR M Headphone Jack Replacement: passo 15, imagem 1 %32
    • Wedge a small plastic opening tool between the top edge of the headphone jack and the rear assembly casing. There is adhesive securing the headphone jack so you may need to use a decent amount of force to pry away the headphone jack from its clear plastic casing.
Conclusão
Uma outra pessoa concluiu este guia.
Ethan Look
Membro desde: 04/21/15
498 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-1, Amido Spring 2015 Membro de Cal Poly, Team 15-1, Amido Spring 2015
CPSU-AMIDO-S15S15G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 574
