Ir para o conteúdo principal
Motorola Droid RAZR M Battery Door Glass Lens Replacement
O que você precisa
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: passo 1, imagem 1 %32
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: passo 2, imagem 1 %32
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: passo 3, imagem 1 %32
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: passo 4, imagem 1 %32
    • Done :-)
Linha de Chegada
4 outras pessoas executaram este guia.
Alex R
Membro desde: 09/27/13
215 Reputação
Autoria de 1 guia
3 comentários
This is not a razr maxx !!!!
Fausto Lebron - Responder
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - Responder
This is Droid razr m . not maxx
Qais Afridi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,377
