Introdução
You just came back from vacation in Hawaii, but because your rear camera wasn't working, you didn't get a single picture. With this guide, you can make sure this doesn't happen again.
O que você precisa
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
Using tweezers, remove the metal shield protecting the rear facing camera.
2 outras pessoas concluíram este guia.
