Ir para o conteúdo principal
Motorola Droid RAZR HD Battery Replacement
O que você precisa
  1. Motorola Droid RAZR HD Battery Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
  2. Motorola Droid RAZR HD Battery Replacement: passo 2, imagem 1 %32
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
  3. Motorola Droid RAZR HD Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
  4. Motorola Droid RAZR HD Battery Replacement: passo 4, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 4, imagem 2 %32
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
  5. Motorola Droid RAZR HD Battery Replacement: passo 5, imagem 1 %32
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
  6. Motorola Droid RAZR HD Battery Replacement, Rear Facing Camera: passo 6, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement, Rear Facing Camera: passo 6, imagem 2 %32
    • Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
    • Using tweezers, remove the metal shield protecting the rear facing camera.
  7. Motorola Droid RAZR HD Battery Replacement: passo 7, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to lift up the rear camera.
    • Use tweezers to lift and unlock the black bar on top of the rear camera's ZIF connector.
    • Pull the camera out of the connector.
    • You will need to unplug the rear camera from its connector on the motherboard.
  8. Motorola Droid RAZR HD Battery Replacement, Motherboard: passo 8, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement, Motherboard: passo 8, imagem 2 %32
    • Remove the two 3.5mm Torx T4 screws securing the headphone jack cable/cover.
    • Using tweezers, disconnect the headphone jack cable/cover and remove it. The headphone jack will stay where it is.
    • The metal shield is attached to the headphone jack.
  9. Motorola Droid RAZR HD Battery Replacement: passo 9, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 9, imagem 2 %32 Motorola Droid RAZR HD Battery Replacement: passo 9, imagem 3 %32
    • Using a plastic opening tool or tweezers, disconnect the power button connector.
    • Carefully peel back the adhesive cable with the tweezers so it is not in the way of the motherboard.
  10. Motorola Droid RAZR HD Battery Replacement: passo 10, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 10, imagem 2 %32
    • Disconnect the battery from the motherboard by lifting up with the plastic opening tool near the base of the cable.
    • Bend the battery cable straight up and out of the way of the motherboard.
  11. Motorola Droid RAZR HD Battery Replacement: passo 11, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 11, imagem 2 %32
    • Using tweezers, peel back the adhesive covering the speaker connector.
    • Using tweezers, disconnect the speaker connector by lifting underneath the base of the connector.
  12. Motorola Droid RAZR HD Battery Replacement: passo 12, imagem 1 %32
    • Locate the sim card/micro sd tray on the side of the device.
    • Push a small rod, such as a paper clip or sim card tool, into the opening to eject and remove the tray.
  13. Motorola Droid RAZR HD Battery Replacement: passo 13, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement: passo 13, imagem 2 %32
    • Remove the six 3.5mm Torx T4 screws securing the motherboard to the device frame.
    • Carefully pry up the motherboard from the frame using a plastic opening tool.
    • Watch for obstructions such as loose cables.
  14. Motorola Droid RAZR HD Battery Replacement, Battery: passo 14, imagem 1 %32 Motorola Droid RAZR HD Battery Replacement, Battery: passo 14, imagem 2 %32
    • Use a plastic opening tool to lift up the battery from the frame of the device.
    • Remove the battery.
Conclusão
7 outras pessoas executaram este guia.
Blake Nielsen
Membro desde: 04/14/15
530 Reputação
3 Guias de autoria
Equipe
Cal Poly, Team 4-4, Maness Spring 2015 Membro de Cal Poly, Team 4-4, Maness Spring 2015
CPSU-MANESS-S15S4G4
5 Membros
12 Guias de autoria
3 comentários
I replaced the battery and got my phone. now I have a date - January 1, 1970. it does not fix it. maybe You know the solution
Spartak Aznabaev - Responder
Good Guide. But I bent the battery when I was taking it out because it was glued down. Also it would have been nice to walk through the reassembly/ Some parts were tricky. It does not do any good to take apart phone if you cannot put it back together.
Michael Horwitz - Responder
Excellent guide. I needed to replace the battery in my old phone because the old one had gone bad and swollen badly. So bad it had pushed the back cover off, which isn’t supposed to come off. I now need to re-glue the back onto the phone. Any suggestion on type of glue to do that? Thanks!
Toney Privatte - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 3,517
