Introdução
The earpiece speaker assembly provides sound for voice calls and houses the upper microphone.
Ferramentas
Peças
Nenhum componente especificado.
Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
Pry the back cover up with the plastic opening tool to free the plastic clips.
Continue prying along the left edge of the back cover towards the top of the phone.
Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
Gently pry up the bottom edge of the camera cover with a plastic opening tool.
Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
Remove the six screws securing the rear case to the rest of the phone:
three 6.7 mm silver T3 Torx screws at the top,
four 4.0 mm gold T3 Torx screws in the middle,
and three 4.5 mm black T5 Torx screws at the bottom.
Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
Remove the metal chassis from the motherboard assembly.
Lift up the anti-static tape covering the camera and earpiece ZIF connectors with the tip of a spudger.
Peel back the tape and remove it.
Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
Flip up the tab on the earpiece speaker ZIF connector with your finger or a plastic opening tool.
Remove the earpiece speaker from the motherboard.
Uma outra pessoa concluiu este guia.
