Ir para o conteúdo principal
Motorola Droid RAZR Back Cover Replacement
O que você precisa
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Droid RAZR Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: passo 2, imagem 1 %32 Motorola Droid RAZR Back Cover Replacement: passo 2, imagem 2 %32 Motorola Droid RAZR Back Cover Replacement: passo 2, imagem 3 %32
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: passo 3, imagem 1 %32 Motorola Droid RAZR Back Cover Replacement: passo 3, imagem 2 %32 Motorola Droid RAZR Back Cover Replacement: passo 3, imagem 3 %32
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Conclusão
7 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
150.997 Reputação
Autoria de 127 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 14,261
