Ir para o conteúdo principal
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
O que você precisa
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 2, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 2, imagem 2 %32
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 2 %32
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 4, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 4, imagem 2 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 5, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 5, imagem 2 %32
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
Conclusão
Kyle Shays
Membro desde: 10/28/15
836 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-6, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
Membros da 3
Autoria de 12 guias
Um comentário
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 335
