Introdução
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
O que você precisa
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Um comentário
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
