Ir para o conteúdo principal
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
O que você precisa
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: passo 1, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: passo 1, imagem 2 %32
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 2, imagem 1 %32
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 3, imagem 1 %32
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 4, imagem 1 %32 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: passo 4, imagem 2 %32
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
Conclusão
Peter Cakounes
Membro desde: 10/21/14
19 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 216
