Ir para o conteúdo principal
Motorola Droid Pro Keyboard Replacement
O que você precisa
  1. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: passo 1, imagem 1 %32 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: passo 1, imagem 2 %32
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Keyboard Replacement: passo 2, imagem 1 %32
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Keyboard Replacement: passo 3, imagem 1 %32
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Keyboard Replacement: passo 4, imagem 1 %32 Motorola Droid Pro Keyboard Replacement: passo 4, imagem 2 %32
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Keyboard Replacement, Screen: passo 5, imagem 1 %32
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Keyboard Replacement: passo 6, imagem 1 %32
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
  7. Motorola Droid Pro Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Pop out key board using a spudger on the marked points.
    • The keyboard is locked in place, but can pop in and out. You may need to use a little force to get it out.
    • Once out you can pop the new keyboard in the opposite way you took it out.
Conclusão
Peter Cakounes
Membro desde: 10/21/14
19 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 189
