Pular para o conteúdo principal
Introdução
This guide will show you how to replace the earpiece speaker on a Motorola Droid MAXX 2 smartphone.
Peças
Nenhum componente especificado.
  1. Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Pull the sim card tray up out of the phone
    • Pull the sim card tray up out of the phone
  3. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
  6. Pull the mid-frame off of the phone.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  7. Remove the static tape covering the two connectors. Use a spudger to disconnect the battery cables from the motherboard. If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  8. Remove the disconnected battery from the phone.
    • Remove the disconnected battery from the phone.
  9. Grab the speaker with the tweezers and gently pull up on the speaker.
    • Grab the speaker with the tweezers and gently pull up on the speaker.
    • The speaker is held in place around the edges with adhesive, so there will be some resistance when you try to remove the speaker from the phone.
Conclusão
Burke Seggerman
Membro desde: 18-03-2018
580 reputação
5 Guias de autoria
Equipe
Baylor, Team S3-G4, Williams Spring 2018 Membro de Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Todo: 257
