Ir para o conteúdo principal
Motorola Droid MAXX 2 Button Assembly Replacement
O que você precisa
  1. Motorola Droid MAXX 2 Button Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Button Assembly Replacement: passo 2, imagem 1 %32
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Button Assembly Replacement: passo 3, imagem 1 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 3, imagem 2 %32
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Button Assembly Replacement: passo 4, imagem 1 %32
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Button Assembly Replacement: passo 5, imagem 1 %32
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Button Assembly Replacement: passo 6, imagem 1 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 6, imagem 2 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 6, imagem 3 %32
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Button Assembly Replacement: passo 7, imagem 1 %32
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: passo 8, imagem 1 %32 Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: passo 8, imagem 2 %32
    • Peel back the orange adhesive covering the ZIF connector.
  9. Motorola Droid MAXX 2 Button Assembly Replacement: passo 9, imagem 1 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 9, imagem 2 %32
    • Lift the black tab on the ZIF connector up.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Button Assembly Replacement: passo 10, imagem 1 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 10, imagem 2 %32 Motorola Droid MAXX 2 Button Assembly Replacement: passo 10, imagem 3 %32
    • Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
  11. Motorola Droid MAXX 2 Button Assembly Replacement: passo 11, imagem 1 %32
    • Pull the button assembly up and out of the phone.
Conclusão
Burke Seggerman
Membro desde: 03/18/18
704 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S3-G4, Williams Spring 2018 Membro de Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 521
