Ir para o conteúdo principal
Motorola Droid Bionic LCD Replacement
O que você precisa
  1. Motorola Droid Bionic LCD Replacement, LCD: passo 1, imagem 1 %32
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: passo 2, imagem 1 %32
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: passo 3, imagem 1 %32 Motorola Droid Bionic LCD Replacement: passo 3, imagem 2 %32
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: passo 4, imagem 1 %32 Motorola Droid Bionic LCD Replacement: passo 4, imagem 2 %32
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: passo 5, imagem 1 %32 Motorola Droid Bionic LCD Replacement: passo 5, imagem 2 %32 Motorola Droid Bionic LCD Replacement: passo 5, imagem 3 %32
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: passo 6, imagem 1 %32
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: passo 7, imagem 1 %32 Motorola Droid Bionic LCD Replacement: passo 7, imagem 2 %32
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: passo 8, imagem 1 %32 Motorola Droid Bionic LCD Replacement: passo 8, imagem 2 %32
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
Conclusão
4 outras pessoas executaram este guia.
Taylor
Membro desde: 08/30/12
244 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,767
