Ir para o conteúdo principal
Motorola Droid 2 Rear Case Replacement
O que você precisa
  1. Motorola Droid 2 Rear Case Replacement, Battery: passo 1, imagem 1 %32 Motorola Droid 2 Rear Case Replacement, Battery: passo 1, imagem 2 %32 Motorola Droid 2 Rear Case Replacement, Battery: passo 1, imagem 3 %32
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Rear Case Replacement: passo 2, imagem 1 %32 Motorola Droid 2 Rear Case Replacement: passo 2, imagem 2 %32
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Rear Case Replacement, Rear Case: passo 3, imagem 1 %32 Motorola Droid 2 Rear Case Replacement, Rear Case: passo 3, imagem 2 %32
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Rear Case Replacement: passo 4, imagem 1 %32
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Rear Case Replacement: passo 5, imagem 1 %32
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Rear Case Replacement: passo 6, imagem 1 %32
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Rear Case Replacement: passo 7, imagem 1 %32
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Rear Case Replacement: passo 8, imagem 1 %32
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Rear Case Replacement: passo 9, imagem 1 %32 Motorola Droid 2 Rear Case Replacement: passo 9, imagem 2 %32
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Rear Case Replacement: passo 10, imagem 1 %32 Motorola Droid 2 Rear Case Replacement: passo 10, imagem 2 %32
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 6,170
