Ir para o conteúdo principal
Motorola Defy XT Screen Replacement
O que você precisa
  1. Motorola Defy XT Screen Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: passo 2, imagem 1 %32
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: passo 3, imagem 1 %32
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: passo 4, imagem 1 %32
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: passo 5, imagem 1 %32 Motorola Defy XT Screen Replacement, Screen: passo 5, imagem 2 %32
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: passo 7, imagem 1 %32
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: passo 8, imagem 1 %32
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: passo 9, imagem 1 %32 Motorola Defy XT Screen Replacement: passo 9, imagem 2 %32
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: passo 10, imagem 1 %32 Motorola Defy XT Screen Replacement: passo 10, imagem 2 %32
    • Set the old screen aside and replace it with your new screen.
Conclusão
Oscar Camacho
Membro desde: 04/19/13
89 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 2-22, Maness Spring 2013 Membro de Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 3,130
