Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will go through the steps of replacing the camera module for the Motorola MB525 starting from the tear down of the phone to replacement of the camera module itself.
  1. Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Use a plastic opening tool to pry the battery out of the phone.
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Unscrew the two silver screws located at the top of the back of the phone.
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Use a plastic opening tool to gently pry the midframe from the rest of the phone.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module. Be careful of the pins that are connected to the camera module on the bottom.
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
Conclusão
Morgan Roark
Membro desde: 08/10/2014
327 Reputação
3 Guias de autoria
Equipe
USF Tampa, Team 14-2, Leahy Fall 2014 Membro de USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 315
