Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
Use a plastic opening tool to pry the battery out of the phone.
Unscrew the two silver screws located at the top of the back of the phone.
Use a plastic opening tool to gently pry the midframe from the rest of the phone.
Use metal spudger to pry off the middle yellow flap carefully.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use tweezers again to pry off the second yellow flap carefully.
The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
