Ir para o conteúdo principal
Motorola Defy Motherboard Replacement
O que você precisa
  1. Motorola Defy Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Defy Motherboard Replacement: passo 2, imagem 1 %32 Motorola Defy Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
    Pergunte ao FixBot
    Comentar
  3. Motorola Defy Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Use a plastic opening tool to pry the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola Defy Motherboard Replacement, Midframe: passo 4, imagem 1 %32
    • Unscrew the two silver screws located at the top of the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola Defy Motherboard Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  6. Motorola Defy Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Motorola Defy Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Use metal spudger to pry off the middle yellow flap carefully.
    Pergunte ao FixBot
    Comentar
  7. Motorola Defy Motherboard Replacement: passo 7, imagem 1 %32 Motorola Defy Motherboard Replacement: passo 7, imagem 2 %32 Motorola Defy Motherboard Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers again to pry off the second yellow flap carefully.
    Pergunte ao FixBot
    Comentar
  8. Motorola Defy Motherboard Replacement: passo 8, imagem 1 %32
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
    Pergunte ao FixBot
    Comentar
Conclusão
Romario
Membro desde: 10/08/14
102 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 14-2, Leahy Fall 2014 Membro de USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 1,137
