Ir para o conteúdo principal
Motorola Defy LCD Replacement
O que você precisa
  1. Motorola Defy LCD Replacement, Rear Case: passo 1, imagem 1 %32
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Defy LCD Replacement: passo 2, imagem 1 %32 Motorola Defy LCD Replacement: passo 2, imagem 2 %32
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
    Pergunte ao FixBot
    Comentar
  3. Motorola Defy LCD Replacement, Battery: passo 3, imagem 1 %32
    • Use a plastic opening tool to pry the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola Defy LCD Replacement, Midframe: passo 4, imagem 1 %32
    • Unscrew the two silver screws located at the top of the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola Defy LCD Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  6. Motorola Defy LCD Replacement, Motherboard: passo 6, imagem 1 %32 Motorola Defy LCD Replacement, Motherboard: passo 6, imagem 2 %32
    • Use metal spudger to pry off the middle yellow flap carefully.
    Pergunte ao FixBot
    Comentar
  7. Motorola Defy LCD Replacement: passo 7, imagem 1 %32 Motorola Defy LCD Replacement: passo 7, imagem 2 %32 Motorola Defy LCD Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers again to pry off the second yellow flap carefully.
    Pergunte ao FixBot
    Comentar
  8. Motorola Defy LCD Replacement: passo 8, imagem 1 %32
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
    Pergunte ao FixBot
    Comentar
  9. Motorola Defy LCD Replacement, Removing the LCD: passo 9, imagem 1 %32 Motorola Defy LCD Replacement, Removing the LCD: passo 9, imagem 2 %32
    • Stick the metal spudger in between the LCD screen and the case of the phone.
    • Remove the LCD screen and replace with a new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 14-2, Leahy Fall 2014 Membro de USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 42
Ao todo: 1,428
