Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will go through the steps of replacing the speaker for the Motorola MB525 starting from the tear down of the phone to replacement of the speaker itself.
O que você precisa
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
