Ir para o conteúdo principal
Motorola DROID RAZR MAXX Camera Cover Replacement
O que você precisa
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: passo 1, imagem 1 %32 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: passo 1, imagem 2 %32
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: passo 2, imagem 1 %32 Motorola DROID RAZR MAXX Camera Cover Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: passo 3, imagem 1 %32 Motorola DROID RAZR MAXX Camera Cover Replacement: passo 3, imagem 2 %32 Motorola DROID RAZR MAXX Camera Cover Replacement: passo 3, imagem 3 %32
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: passo 4, imagem 1 %32
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Govind
Membro desde: 10/08/14
130 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 14-6, Leahy Fall 2014 Membro de USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 716
