Ir para o conteúdo principal
Motorola DROID MAXX Battery Replacement
O que você precisa
  1. Motorola DROID MAXX Battery Replacement, Set Up: passo 1, imagem 1 %32 Motorola DROID MAXX Battery Replacement, Set Up: passo 1, imagem 2 %32
    • Place the Droid Maxx face up on a soft flat plastic surface with plenty of space to place your tools and small parts of the equipment.
    • Lift the Droid Maxx and turn it in a 90-degree angle to your left while you are holding it by the sides with one hand. Maintain the same position all times unless indicated otherwise in subsequent steps.
  2. Motorola DROID MAXX Battery Replacement, Getting Started: passo 2, imagem 1 %32 Motorola DROID MAXX Battery Replacement, Getting Started: passo 2, imagem 2 %32 Motorola DROID MAXX Battery Replacement, Getting Started: passo 2, imagem 3 %32
    • Find the volume buttons located towards the center of the Droid Maxx.
    • With your free hand, take the Spudger and insert it between the upper gap, closest to the screen, of the volume buttons and the Droid Maxx case.
    • Using the flat part of the Spudger’s Tip and pressing firmly against the Droid Maxx case until you hear a “snap” sound
    • With your free hand, remove the buttons carefully with your two fingers and make sure to keep the motion until the piece is completely out of your Droid Maxx. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
  3. Motorola DROID MAXX Battery Replacement, Removing the Back Cover: passo 3, imagem 1 %32 Motorola DROID MAXX Battery Replacement, Removing the Back Cover: passo 3, imagem 2 %32 Motorola DROID MAXX Battery Replacement, Removing the Back Cover: passo 3, imagem 3 %32
    • Tilt the Droid Maxx towards your right so you can see the edge of the rubber back case and keep this position.
    • Take the Spudger and press the tip against the space between the rubber case and the Droid Maxx frame. Slide the Spudger’s edge along the surface until you hear a “snap” sound.
    • Work your way to the top of the Droid Maxx with the Spudger and use your holding hand’s fingers as support while you remove the upper part of the rubber back case. Rotate the Droid Maxx to facilitate your movement if necessary. Do not go along the bottom to remove the case.
    • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
    • Place the rubber back case in a nearby place where it will not interfere with your arms motion.
  4. Motorola DROID MAXX Battery Replacement, Removing the Camera Back Housing: passo 4, imagem 1 %32 Motorola DROID MAXX Battery Replacement, Removing the Camera Back Housing: passo 4, imagem 2 %32 Motorola DROID MAXX Battery Replacement, Removing the Camera Back Housing: passo 4, imagem 3 %32
    • Lay the Droid Maxx face down on the plastic surface to start removing the screws.
    • Take the Torx T5 Screwdriver and carefully remove all the screws in the Droid Maxx’s motherboard. Note that there is a total of eight (11) black screws spread across the motherboard, four (4) at the top and four (4) at the bottom, and also two (2) silver screws located to the right lower part of the Droid Maxx.
    • There is(1) screw holding the camera housing. Use a T4 screwdriver for this one screw.
    • After removing all the screws, lift hold the Droid Maxx as in step 2
    • Locate two (2) tabs in the camera plastic housing , one (1) at each corner of the Droid Maxx
    • Take the Flathead driver and gently lift both tabs to release the camera housing. Be careful because these plastic tabs are very delicate and can break easily.
  5. Motorola DROID MAXX Battery Replacement, Let the Fix Begin!: passo 5, imagem 1 %32
    • Now you are all set! These steps along with images should serve as guide to disassemble your Motorola Droid Maxx in a safe manner. The following guides will indicate how to replace parts of your Droid Maxx such as the camera or battery.
    • Keep in mind that in order to replace any of the aforementioned parts you will be redirected to this general section.
  6. Motorola DROID MAXX Battery Replacement, Getting to the Battery: passo 6, imagem 1 %32 Motorola DROID MAXX Battery Replacement, Getting to the Battery: passo 6, imagem 2 %32 Motorola DROID MAXX Battery Replacement, Getting to the Battery: passo 6, imagem 3 %32
    • Use the flathead screwdriver to gently pry the motherboard out of the rest of the phone.
    • Once the motherboard is loose, detach the flexible connector after removing the anti-static tape.
    • Now you're free to remove the battery
Conclusão
24 outras pessoas executaram este guia.
Nick Zurita
Membro desde: 10/07/14
396 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-6, Leahy Fall 2014 Membro de USF Tampa, Team 7-6, Leahy Fall 2014
USFT-LEAHY-F14S7G6
Membros da 4
Autoria de 6 guias
18 comentários
Don't bother trying to remove the battery on the Droid Maxx, it's not possible without destroying the entire phone.
I spent 2 hours carefully tearing it apart trying to get to the battery only to find out the entire thing is made out of very thin layers of some kind of material wrapped in a thin sheet. The motherboard is physically attached to the battery layers. Its designed this way to make battery removable/ replacement close to impossible.
arnaldo - Responder
I agree. I got the thing disassembled, even though it was a much tougher job than is indicated here, but I am finding it impossible to reassemble the phone. The Verizon store would not even look at repairing it, and says the battery is "not replaceable." I may be able to get this mess fixed elsewhere, but if not I have destroyed my phone by following these instructions.
Brooks -
I have the same issue as the previous comments. I followed these instructions and now my phone cannot make or receive phone calls. I would not recommend attempting to replace the battery on your droid maxx.
Kat - Responder
With tedious and pain staking effort, Battery is replaced. At first it didn't work and had to open it up again. I found the big connector to the screen wasn't in all the way. In retrospect it wasn't that bad.
Randy Glezen - Responder
I have done this for my phone and it wasn't bad. IF you have some experience working with small electronics and IF you take your time and use common sense, it's a simple thing. Previous people in comments must have thought it would be as simple as changing batteries in TV remote. This repair does not require the use of a soldering iron but...... If that is out of your skill set, then this is too.
DeWayne Shorts - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 42
Duração total: 127,883
