Ir para o conteúdo principal
Motorola California Mobile Phone Rear Casing Replacement
O que você precisa
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: passo 1, imagem 1 %32
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: passo 2, imagem 1 %32
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: passo 3, imagem 1 %32
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: passo 4, imagem 1 %32
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: passo 5, imagem 1 %32
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
Conclusão
Andrew Lam
Membro desde: 04/17/12
35 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-46, Regan Spring 2012 Membro de Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 1,001
