Ir para o conteúdo principal
Motorola California Mobile Phone Motherboard Replacement
O que você precisa
  1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: passo 1, imagem 1 %32
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Motherboard Replacement: passo 2, imagem 1 %32
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Motherboard Replacement: passo 3, imagem 1 %32
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Motherboard Replacement: passo 4, imagem 1 %32
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Motherboard Replacement: passo 5, imagem 1 %32
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Motherboard Replacement: passo 6, imagem 1 %32
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  7. Motorola California Mobile Phone Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  8. Motorola California Mobile Phone Motherboard Replacement: passo 8, imagem 1 %32
    • Press firmly on the motherboard until it is snug inside the casing.
Conclusão
Andrew Lam
Membro desde: 04/17/12
53 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-46, Regan Spring 2012 Membro de Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
Membros da 5
Autoria de 8 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 2,897
