Ir para o conteúdo principal
Motorola California Mobile Phone Antenna Replacement
O que você precisa
  1. Motorola California Mobile Phone Antenna Replacement, Antenna: passo 1, imagem 1 %32
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Antenna Replacement: passo 2, imagem 1 %32
    • Insert the Phillips 00 screwdriver into the holes that connect the key pad guard to the rear casing in the plastic rod.
    • The following step may require a substantial amount of force.
    • Use the screwdriver to push the rods towards each other until they click out of their locked positions.
  3. Motorola California Mobile Phone Antenna Replacement: passo 3, imagem 1 %32
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Push the clips outward while simultaneously lifting the rear casing and keyguard away from the front casing.
  4. Motorola California Mobile Phone Antenna Replacement: passo 4, imagem 1 %32
    • Locate and unplug the black component of the current antenna from the motherboard.
    • Under the black component there should be a blue component.
    • Unscrew the blue component in order to free the antenna.
  5. Motorola California Mobile Phone Antenna Replacement: passo 5, imagem 1 %32
    • Slide the antenna out of the green tubing.
    • Slide the green tubing out of its hole.
  6. Motorola California Mobile Phone Antenna Replacement: passo 6, imagem 1 %32
    • Insert the new green tubing into the corresponding slot.
  7. Motorola California Mobile Phone Antenna Replacement: passo 7, imagem 1 %32
    • Insert the new antenna into the green tubing.
  8. Motorola California Mobile Phone Antenna Replacement: passo 8, imagem 1 %32
    • Screw the blue piece of the antenna into the threaded hole on the motherboard until it is tight.
  9. Motorola California Mobile Phone Antenna Replacement: passo 9, imagem 1 %32
    • Align the protruding wire on the black component with the corresponding hole on the motherboard.
    • Push the wire into the hole.
  10. Motorola California Mobile Phone Antenna Replacement: passo 10, imagem 1 %32
    • Reverse the instructions from Step 2 to re-install the keypad guard and rear casing onto the device.
  11. Motorola California Mobile Phone Antenna Replacement: passo 11, imagem 1 %32
    • Push down on the antenna guard until it clicks into place.
Conclusão
Andrew Lam
Membro desde: 04/17/12
53 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-46, Regan Spring 2012 Membro de Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,873
