Ir para o conteúdo principal
Motorola CLS1410 Antenna Replacement
O que você precisa
  1. Motorola CLS1410 Antenna Replacement, Antenna: passo 1, imagem 1 %32 Motorola CLS1410 Antenna Replacement, Antenna: passo 1, imagem 2 %32
    • This Motorola CLS1410 has a damaged antenna where the rubber sheath has come off.
    • These steps also work for antennas that are bent.
    • It is recommended to discharge the battery to a safe level before attempting to replace the antenna.
    • Start by turning off the radio by twisting the volume knob.
    • Remove the holster from the radio.
  2. Motorola CLS1410 Antenna Replacement: passo 2, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 2, imagem 2 %32
    • Remove the battery cover by pressing on the indentation and pushing down.
    • Remove the battery by pressing on the battery at the bottom of the radio and gently lift it away at an angle.
    • Place the battery in a safe location where the contacts cannot be shorted.
    • As with all lithium ion batteries, you must take care to not damage the battery when removing it. Do not use tools to pry the battery out.
    • If the battery is swollen, hot, or otherwise damaged, stop and place the device in a fireproof container for safe disposal in accordance to local laws.
  3. Motorola CLS1410 Antenna Replacement: passo 3, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 3, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 3, imagem 3 %32
    • Insert a spudger between the body of the radio and the volume knob.
    • I've found that moving the spudger to the front of the device helps with leverage to remove the knob.
    • Use your fingers to pull the plastic knob off and set it aside.
  4. Motorola CLS1410 Antenna Replacement: passo 4, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 4, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 4, imagem 3 %32
    • There are two T8 screws hidden under this strap hole at the top of the radio.
    • Use a thin tool, like a spudger or pick to gently pry this cover off and set it aside.
    • There may be some adhesive to hold this cover on and it may be tricky to get a spudger in. You may find it easier to use an inexpensive or disposable size 1 flathead to pop this part off.
  5. Motorola CLS1410 Antenna Replacement: passo 5, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 5, imagem 2 %32
    • There are 6x T8 screws holding the back of the radio on.
    • I believe these are all the same size, but it is a good idea to set them aside so you match which screw goes to which hole.
    • Remove these 6x T8 screws.
  6. Motorola CLS1410 Antenna Replacement: passo 6, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 6, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 6, imagem 3 %32
    • Peel back the serial number sticker from this plate in the battery compartment.
    • Starting at the bottom, gently use your fingers or a spudger to separate the front and back halves of the radio.
    • There are wires holding the speaker to the front of the case, so be careful to not pull too far.
    • Some versions of the CLS1410 use a spring connector instead of a wire.
    • Set the front half to the side of the radio.
  7. Motorola CLS1410 Antenna Replacement: passo 7, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 7, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 7, imagem 3 %32
    • There is 1x T8 screw holding the antenna to the circuit board and the back of the case.
    • Remove this T8 screw and set it aside.
    • I believe this T8 screw is the same size, but continue to keep track of which one is which.
  8. Motorola CLS1410 Antenna Replacement: passo 8, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 8, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 8, imagem 3 %32
    • Gently lift the circuit board by the bottom and pivot it upwards slightly.
    • There is a small metal pin holding the board at the top left. Once you have lifted it enough to clear this, you can pull down so to remove the volume knob from its hole.
    • There are two wires from the back of the case to the circuit board. Take care to not break them when lifting the board up.
  9. Motorola CLS1410 Antenna Replacement: passo 9, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 9, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 9, imagem 3 %32
    • Lift the antenna straight up out of the back of the case and set it aside to be recycled or disposed of.
  10. Motorola CLS1410 Antenna Replacement: passo 10, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 10, imagem 2 %32
    • Set the replacement antenna into the slot.
    • Only replace the antenna with one of the same size and type.
    • You are responsible to follow all laws and regulations governing your use of this radio. Modifying this radio to accept a different type of antenna or connector may not be legal in your jurisdiction.
  11. Motorola CLS1410 Antenna Replacement: passo 11, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 11, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 11, imagem 3 %32
    • Slide the circuit board back into the back of the case.
    • There's a small pin on the top left of the back of the case that slots into a hole in the board. This may be a little tricky to get it to fit back in while sliding the volume knob back in.
  12. Motorola CLS1410 Antenna Replacement: passo 12, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 12, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 12, imagem 3 %32
    • Reinstall the 1x T8 screw that holds the board to the back of the case through the antenna.
    • The antenna loop sits against the bottom of the board, not the top.
    • Set the front of the case on the rest of the radio and press together gently to get it to latch.
  13. Motorola CLS1410 Antenna Replacement: passo 13, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 13, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 13, imagem 3 %32
    • Push the serial number sticker back down to the metal plate on the exposed section of the battery case.
    • Reinstall all 6x T8 screws, 2x in the top portion and 4x in the battery compartment.
    • Replace the strap cover at the top back of the radio.
    • The strap cover does not appear to be necessary to protect the radio. You may either choose to replace the adhesive, place it back without the adhesive, or not replace it at all.
    • Replace the volume knob.
    • The plastic volume knob has a flat section that aligns with the flat section of the metal.
  14. Motorola CLS1410 Antenna Replacement: passo 14, imagem 1 %32 Motorola CLS1410 Antenna Replacement: passo 14, imagem 2 %32 Motorola CLS1410 Antenna Replacement: passo 14, imagem 3 %32
    • Replace the battery.
    • Put the battery against the contacts and pivot the other side down into the battery compartment. The fit is snug.
    • Replace the battery cover.
    • Replace the holster.
  15. Motorola CLS1410 Antenna Replacement: passo 15, imagem 1 %32
    • Charge the battery and test transmitting and receiving.
Linha de Chegada
drivec
Membro desde: 07/01/14
256 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 39
