Ir para o conteúdo principal
Motorola C350 Logic Board Replacement
O que você precisa
  1. Motorola C350 Logic Board Replacement, Rear case freeing: passo 1, imagem 1 %32 Motorola C350 Logic Board Replacement, Rear case freeing: passo 1, imagem 2 %32
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Logic Board Replacement, Removing battery: passo 2, imagem 1 %32
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Logic Board Replacement, Separating the front case: passo 3, imagem 1 %32 Motorola C350 Logic Board Replacement, Separating the front case: passo 3, imagem 2 %32
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Logic Board Replacement, Logic Board: passo 4, imagem 1 %32 Motorola C350 Logic Board Replacement, Logic Board: passo 4, imagem 2 %32
    • Remove the 4 T6 Torx screws
  5. Motorola C350 Logic Board Replacement: passo 5, imagem 1 %32 Motorola C350 Logic Board Replacement: passo 5, imagem 2 %32
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  6. Motorola C350 Logic Board Replacement: passo 6, imagem 1 %32
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
Conclusão
Vincent Monteil
Membro desde: 07/06/13
6.975 Reputação
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 496
