Introdução
Use this guide to replace the front case on your Motorola C350.
Ferramentas
Não são necessárias ferramentas.
Peças
Não são necessárias peças.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  4. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Conclusão
2 outras pessoas concluíram este guia.
Vincent Monteil
6.221 reputação
19 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 222
