Ir para o conteúdo principal
Motorola C290 Speaker Replacement
O que você precisa
  1. Motorola C290 Speaker Replacement, Outside Case removal: passo 1, imagem 1 %32 Motorola C290 Speaker Replacement, Outside Case removal: passo 1, imagem 2 %32 Motorola C290 Speaker Replacement, Outside Case removal: passo 1, imagem 3 %32
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Speaker Replacement, Removing the front casing: passo 2, imagem 1 %32 Motorola C290 Speaker Replacement, Removing the front casing: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Speaker Replacement, Disconnect the motherboard: passo 3, imagem 1 %32 Motorola C290 Speaker Replacement, Disconnect the motherboard: passo 3, imagem 2 %32
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Speaker Replacement, Removing the motherboard/screen: passo 4, imagem 1 %32 Motorola C290 Speaker Replacement, Removing the motherboard/screen: passo 4, imagem 2 %32 Motorola C290 Speaker Replacement, Removing the motherboard/screen: passo 4, imagem 3 %32
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  5. Motorola C290 Speaker Replacement, Speaker Removal: passo 5, imagem 1 %32 Motorola C290 Speaker Replacement, Speaker Removal: passo 5, imagem 2 %32 Motorola C290 Speaker Replacement, Speaker Removal: passo 5, imagem 3 %32
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
Conclusão
Philip Ybarra
Membro desde: 04/15/10
27 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-28, Regan Spring 2010 Membro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,166
