Ir para o conteúdo principal
Motorola C290 Keypad Replacement
O que você precisa
  1. Motorola C290 Keypad Replacement, Battery: passo 1, imagem 1 %32 Motorola C290 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
    Pergunte ao FixBot
    Comentar
  2. Motorola C290 Keypad Replacement: passo 2, imagem 1 %32 Motorola C290 Keypad Replacement: passo 2, imagem 2 %32
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola C290 Keypad Replacement, Antenna: passo 3, imagem 1 %32 Motorola C290 Keypad Replacement, Antenna: passo 3, imagem 2 %32 Motorola C290 Keypad Replacement, Antenna: passo 3, imagem 3 %32
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
    Pergunte ao FixBot
    Comentar
  4. Motorola C290 Keypad Replacement: passo 4, imagem 1 %32 Motorola C290 Keypad Replacement: passo 4, imagem 2 %32
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
    Pergunte ao FixBot
    Comentar
  5. Motorola C290 Keypad Replacement, Logic Board: passo 5, imagem 1 %32 Motorola C290 Keypad Replacement, Logic Board: passo 5, imagem 2 %32 Motorola C290 Keypad Replacement, Logic Board: passo 5, imagem 3 %32
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
    Pergunte ao FixBot
    Comentar
  6. Motorola C290 Keypad Replacement: passo 6, imagem 1 %32 Motorola C290 Keypad Replacement: passo 6, imagem 2 %32
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
    Pergunte ao FixBot
    Comentar
  7. Motorola C290 Keypad Replacement: passo 7, imagem 1 %32 Motorola C290 Keypad Replacement: passo 7, imagem 2 %32
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
    Pergunte ao FixBot
    Comentar
  8. Motorola C290 Keypad Replacement: passo 8, imagem 1 %32
    • Use the Spudger to detach the screen wire from the logic board.
    Pergunte ao FixBot
    Comentar
  9. Motorola C290 Keypad Replacement: passo 9, imagem 1 %32 Motorola C290 Keypad Replacement: passo 9, imagem 2 %32 Motorola C290 Keypad Replacement: passo 9, imagem 3 %32
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
    Pergunte ao FixBot
    Comentar
  10. Motorola C290 Keypad Replacement, Keypad: passo 10, imagem 1 %32
    • Use your fingers to pull out the keypad.
    • Note: The keys and rubber backing are one piece.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 24-28, Regan Spring 2010 Membro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 48
Ao todo: 1,412
