Ir para o conteúdo principal
Motorola C290 Antenna Replacement
  1. Motorola C290 Antenna Replacement, Battery: passo 1, imagem 1 %32 Motorola C290 Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Antenna Replacement: passo 2, imagem 1 %32 Motorola C290 Antenna Replacement: passo 2, imagem 2 %32
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Antenna Replacement, Antenna: passo 3, imagem 1 %32 Motorola C290 Antenna Replacement, Antenna: passo 3, imagem 2 %32 Motorola C290 Antenna Replacement, Antenna: passo 3, imagem 3 %32
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Antenna Replacement: passo 4, imagem 1 %32 Motorola C290 Antenna Replacement: passo 4, imagem 2 %32
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 24-28, Regan Spring 2010 Membro de Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,999
