Ir para o conteúdo principal
Motorola C168 Screen Replacement
O que você precisa
  1. Motorola C168 Screen Replacement, Battery: passo 1, imagem 1 %32 Motorola C168 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Screen Replacement: passo 2, imagem 1 %32 Motorola C168 Screen Replacement: passo 2, imagem 2 %32
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Screen Replacement, SIM Card: passo 3, imagem 1 %32 Motorola C168 Screen Replacement, SIM Card: passo 3, imagem 2 %32
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Screen Replacement, Front Panel: passo 4, imagem 1 %32 Motorola C168 Screen Replacement, Front Panel: passo 4, imagem 2 %32
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Screen Replacement: passo 5, imagem 1 %32 Motorola C168 Screen Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
  6. Motorola C168 Screen Replacement, Screen: passo 6, imagem 1 %32 Motorola C168 Screen Replacement, Screen: passo 6, imagem 2 %32
    Spudger
    $3.99
    Comprar
    • Place the phone on its back.
    • Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Remove the circuit board from the frame.
    • Removing the board takes more force than you would expect.
  7. Motorola C168 Screen Replacement: passo 7, imagem 1 %32 Motorola C168 Screen Replacement: passo 7, imagem 2 %32
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  8. Motorola C168 Screen Replacement: passo 8, imagem 1 %32 Motorola C168 Screen Replacement: passo 8, imagem 2 %32
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Wu
Membro desde: 04/17/12
37 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-40, Regan Spring 2012 Membro de Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
Membros da 4
Autoria de 8 guias
2 comentários
motorola c168 network not working problem. how to repair network problem?
sattar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,363
