Ir para o conteúdo principal
Motorola C168 Front Panel Replacement
O que você precisa
  1. Motorola C168 Front Panel Replacement, Battery: passo 1, imagem 1 %32 Motorola C168 Front Panel Replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: passo 2, imagem 1 %32 Motorola C168 Front Panel Replacement: passo 2, imagem 2 %32
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: passo 3, imagem 1 %32 Motorola C168 Front Panel Replacement, SIM Card: passo 3, imagem 2 %32
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: passo 4, imagem 1 %32 Motorola C168 Front Panel Replacement, Front Panel: passo 4, imagem 2 %32
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: passo 5, imagem 1 %32 Motorola C168 Front Panel Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Wu
Membro desde: 04/17/12
37 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-40, Regan Spring 2012 Membro de Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,019
