Ir para o conteúdo principal
Motorola C139 Vibration Mechanism Replacement
O que você precisa
  1. Motorola C139 Vibration Mechanism Replacement, Battery: passo 1, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement, Battery: passo 1, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement, Battery: passo 1, imagem 3 %32
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Motorola C139 Vibration Mechanism Replacement: passo 2, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement: passo 2, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement: passo 2, imagem 3 %32
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Motorola C139 Vibration Mechanism Replacement, SIM Card: passo 3, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement, SIM Card: passo 3, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement, SIM Card: passo 3, imagem 3 %32
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
  4. Motorola C139 Vibration Mechanism Replacement, Rear Casing: passo 4, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement, Rear Casing: passo 4, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement, Rear Casing: passo 4, imagem 3 %32
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61 mm in diameter.
  5. Motorola C139 Vibration Mechanism Replacement: passo 5, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement: passo 5, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement: passo 5, imagem 3 %32
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side.
  6. Motorola C139 Vibration Mechanism Replacement: passo 6, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement: passo 6, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement: passo 6, imagem 3 %32
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  7. Motorola C139 Vibration Mechanism Replacement: passo 7, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement: passo 7, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement: passo 7, imagem 3 %32
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  8. Motorola C139 Vibration Mechanism Replacement: passo 8, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement: passo 8, imagem 2 %32 Motorola C139 Vibration Mechanism Replacement: passo 8, imagem 3 %32
    • Use plastic opening tools to free the circuit board from the case.
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case.
  9. Motorola C139 Vibration Mechanism Replacement, Vibration Mechanism: passo 9, imagem 1 %32 Motorola C139 Vibration Mechanism Replacement, Vibration Mechanism: passo 9, imagem 2 %32
    • Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing.
Conclusão
Kyle Olbrich
Membro desde: 03/09/12
30 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 2-2, Benson Spring 2012 Membro de Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 12
Duração total: 1,067
