Ir para o conteúdo principal
Motorola C139 SIM Card Replacement
  1. Motorola C139 SIM Card Replacement, Battery: passo 1, imagem 1 %32 Motorola C139 SIM Card Replacement, Battery: passo 1, imagem 2 %32 Motorola C139 SIM Card Replacement, Battery: passo 1, imagem 3 %32
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Motorola C139 SIM Card Replacement: passo 2, imagem 1 %32 Motorola C139 SIM Card Replacement: passo 2, imagem 2 %32 Motorola C139 SIM Card Replacement: passo 2, imagem 3 %32
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola C139 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 Motorola C139 SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 Motorola C139 SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 2-2, Benson Spring 2012 Membro de Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 29
Ao todo: 2,334
