Introdução
This guide details the steps involved with replacing the keypad or faceplate on the Motorola C139
Peças
Não são necessárias peças.
  1. Begin by flipping your phone over so that the back cover is facing up.
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
      • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • Use plastic pry tools to free the circuit board from the case
      • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case
    • On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone.
Conclusão
Christopher Stubbs
35 reputação
4 Guides authored
Equipe
Clemson, Team 2-2, Benson Spring 2012 Membro de Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Membros
15 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 897
