Ir para o conteúdo principal
Motorola Buzz ic502 SIM card Replacement
  1. Motorola Buzz ic502 SIM card Replacement, Battery: passo 1, imagem 1 %32 Motorola Buzz ic502 SIM card Replacement, Battery: passo 1, imagem 2 %32 Motorola Buzz ic502 SIM card Replacement, Battery: passo 1, imagem 3 %32
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 SIM card Replacement: passo 2, imagem 1 %32 Motorola Buzz ic502 SIM card Replacement: passo 2, imagem 2 %32
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 SIM card Replacement: passo 3, imagem 1 %32 Motorola Buzz ic502 SIM card Replacement: passo 3, imagem 2 %32 Motorola Buzz ic502 SIM card Replacement: passo 3, imagem 3 %32
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 SIM card Replacement, SIM card: passo 4, imagem 1 %32 Motorola Buzz ic502 SIM card Replacement, SIM card: passo 4, imagem 2 %32 Motorola Buzz ic502 SIM card Replacement, SIM card: passo 4, imagem 3 %32
    • The SIM card is located here
    • Carefully push the SIM card down from the top with your finger
    • Make sure to hold card from sides and do not touch the marked spot on card
Conclusão
Austin Quinn
Membro desde: 10/20/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 6-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 147
