Ir para o conteúdo principal
Motorola Buzz ic502 Keypad Replacement
O que você precisa
  1. Motorola Buzz ic502 Keypad Replacement, Battery: passo 1, imagem 1 %32 Motorola Buzz ic502 Keypad Replacement, Battery: passo 1, imagem 2 %32 Motorola Buzz ic502 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Keypad Replacement: passo 2, imagem 1 %32 Motorola Buzz ic502 Keypad Replacement: passo 2, imagem 2 %32
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Keypad Replacement: passo 3, imagem 1 %32 Motorola Buzz ic502 Keypad Replacement: passo 3, imagem 2 %32 Motorola Buzz ic502 Keypad Replacement: passo 3, imagem 3 %32
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Keypad Replacement, Keypad: passo 4, imagem 1 %32 Motorola Buzz ic502 Keypad Replacement, Keypad: passo 4, imagem 2 %32
    • Remove the plastic pieces with metal spudge
    • Under both are two screws, remove those as well.
    • Remove the other four screws on back of phone.
  5. Motorola Buzz ic502 Keypad Replacement: passo 5, imagem 1 %32
    • Carefully lift screen as to not snap wire that connects it (shown is a version in which the screen has been fully removed).
    • Lift off keypad and replace.
Conclusão
Austin Quinn
Membro desde: 10/20/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 6-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 91
