Ir para o conteúdo principal
Motorola Atrix HD Battery Replacement
O que você precisa
  1. Motorola Atrix HD Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola Atrix HD Battery Replacement, Battery: passo 1, imagem 2 %32 Motorola Atrix HD Battery Replacement, Battery: passo 1, imagem 3 %32
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
  2. Motorola Atrix HD Battery Replacement: passo 2, imagem 1 %32
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
  3. Motorola Atrix HD Battery Replacement: passo 3, imagem 1 %32 Motorola Atrix HD Battery Replacement: passo 3, imagem 2 %32 Motorola Atrix HD Battery Replacement: passo 3, imagem 3 %32
    • Remove the red rubber screw cover with a pair of tweezers
  4. Motorola Atrix HD Battery Replacement: passo 4, imagem 1 %32 Motorola Atrix HD Battery Replacement: passo 4, imagem 2 %32
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
  5. Motorola Atrix HD Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
  6. Motorola Atrix HD Battery Replacement: passo 6, imagem 1 %32 Motorola Atrix HD Battery Replacement: passo 6, imagem 2 %32 Motorola Atrix HD Battery Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
  7. Motorola Atrix HD Battery Replacement: passo 7, imagem 1 %32
    • The battery may now be removed.
Conclusão
4 outras pessoas executaram este guia.
Bradley Hinckley
Membro desde: 10/28/15
561 Reputação
2 Guias de autoria
Equipe
UMass Dartmouth, Team 1-8, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Membros
10 Guias de autoria
Um comentário
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 3,153
