Ir para o conteúdo principal
Motorola Atrix 4G Screen Replacement
O que você precisa
  1. Motorola Atrix 4G Screen Replacement, Battery: passo 1, imagem 1 %32
    • Pry the rear cover from the back of the phone.
    Use the word "prying" rather than sliding. We were confused during this step.
    Ben Sweeney - Responder
  2. Motorola Atrix 4G Screen Replacement: passo 2, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 2, imagem 2 %32
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Screen Replacement, Antenna: passo 3, imagem 1 %32 Motorola Atrix 4G Screen Replacement, Antenna: passo 3, imagem 2 %32 Motorola Atrix 4G Screen Replacement, Antenna: passo 3, imagem 3 %32
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
    Not a phillips head screwdriver. Indicate the appropriate tool.
    Hex head screwdriver.
  4. Motorola Atrix 4G Screen Replacement: passo 4, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 4, imagem 2 %32
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
    Red boxes around the tabs so all can be seen clearly. Change the bullet point to red to accommodate said boxes.
    rubixtriangle - Responder
  5. Motorola Atrix 4G Screen Replacement: passo 5, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 5, imagem 2 %32
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Screen Replacement: passo 6, imagem 1 %32
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Screen Replacement: passo 7, imagem 1 %32
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
    Specify--lift beneath it near the gold metal piece located on the phone (not the back case)
  8. Motorola Atrix 4G Screen Replacement: passo 8, imagem 1 %32
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
    Add picture for "easing out of the guide." Also, specify that you must unclip the guide from the phone.
  9. Motorola Atrix 4G Screen Replacement, Motherboard: passo 9, imagem 1 %32 Motorola Atrix 4G Screen Replacement, Motherboard: passo 9, imagem 2 %32
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
    Specify "right side."
    Not clear instructions. Clear/white rubber piece came off during removal--make a note of that possibility.
  10. Motorola Atrix 4G Screen Replacement: passo 10, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 10, imagem 2 %32
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
    Add color bullets.
  11. Motorola Atrix 4G Screen Replacement: passo 11, imagem 1 %32
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
  12. Motorola Atrix 4G Screen Replacement, Screen: passo 12, imagem 1 %32
    • Using a heat gun or a hair dryer on high heat, soften the adhesive securing the glass screen.
    • Direct the hot air along the front edges of the glass until the phone is warm to the touch.
  13. Motorola Atrix 4G Screen Replacement: passo 13, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 13, imagem 2 %32 Motorola Atrix 4G Screen Replacement: passo 13, imagem 3 %32
    • Using a plastic opening tool, carefully pry up the bottom of the display glass.
    • Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
    • As you work, the adhesive may cool and harden. You may need to heat up the glass again as you work your way around the screen.
  14. Motorola Atrix 4G Screen Replacement: passo 14, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 14, imagem 2 %32
    • Using a spudger, lift up the digitizer cable that is attached to the glass.
    • Be careful not to damage the cable. It is glued in place and hard to remove.
  15. Motorola Atrix 4G Screen Replacement: passo 15, imagem 1 %32 Motorola Atrix 4G Screen Replacement: passo 15, imagem 2 %32 Motorola Atrix 4G Screen Replacement: passo 15, imagem 3 %32
    • Now that the cable has been removed you can slide it through the opening and detach the glass.
    • Be careful as you pull the cable through the opening. The cable is easily damaged.
    • Once the cable is pushed through the slot, the glass can be fully removed.
Conclusão
14 outras pessoas executaram este guia.
Jake
Membro desde: 04/19/12
515 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-42, Regan Spring 2012 Membro de Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
Membros da 6
Autoria de 15 guias
4 comentários
Caution! It is IMPOSSIBLE to insert the cable of the digitizer through the opening without REMOVING FIRST the screen (not the digitizer).
The two parts of the cable of the digitizer (connector + chip) are glued together when you remove the broken one, but in the replacement, if you glue together they don't pass trought the hole without removing the screen.
If someone has arrived to pass them without removing the screen, congratulations: I've broken the cable of a new screen in the process :(
Hector Castillo - Responder
I had to do this process twice, and here's what I've learned:
1) The motherboard does not need to be removed. I suspect this guide has you remove it so you don't damage any components when heating the screen, but there's no physical reason to remove it.
2) Yes, passing the digitizer cable/chip through the hole in the plastic housing is a royal PIA. I may have ruined the first screen I tried it with. Doh! For the second go round, instead of removing the LCD (like Hector recommends above), I just made the hole bigger. How, you ask? I took an emory nail file and trimmed it with scissors to be just narrower than the hole - then I filed away! With a few minutes of careful filing, I was able to double the size of the hole the cable has to pass through. Voila! There's still plenty of plastic left for the double-sided tape to be applied on the inside. Just be sure to clean up all the plastic dust first with a small vacuum or Q-tip before re-installing the screen.
Ben Lake - Responder
tried this, broke first replacement digitizer screen , learned how to procede, Hector appears to be right if you remove the lcd screen it appears to double the size of the hole the cable passes through. what i would also like to see here are the following:
what material to use to "glue" the digitzer chip/connector together and in step 16 it shows the digitzer cable being removed from the metal it is attached to...how/what does one reattach it with?
Scott - Responder
Did anyone ever answer how to glue the flat cable (ground?) back on?
julieistesting -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 19
Duração total: 21,450
