Ir para o conteúdo principal
Motorola Atrix 4G Antenna Replacement
O que você precisa
  1. Motorola Atrix 4G Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Antenna Replacement: passo 2, imagem 1 %32 Motorola Atrix 4G Antenna Replacement: passo 2, imagem 2 %32
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Antenna Replacement, Antenna: passo 3, imagem 1 %32 Motorola Atrix 4G Antenna Replacement, Antenna: passo 3, imagem 2 %32 Motorola Atrix 4G Antenna Replacement, Antenna: passo 3, imagem 3 %32
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Antenna Replacement: passo 4, imagem 1 %32 Motorola Atrix 4G Antenna Replacement: passo 4, imagem 2 %32
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Antenna Replacement: passo 5, imagem 1 %32 Motorola Atrix 4G Antenna Replacement: passo 5, imagem 2 %32
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Antenna Replacement: passo 6, imagem 1 %32
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Antenna Replacement: passo 7, imagem 1 %32
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Antenna Replacement: passo 8, imagem 1 %32
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
Conclusão
5 outras pessoas executaram este guia.
Derek Walker
Membro desde: 04/19/12
297 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-42, Regan Spring 2012 Membro de Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
Membros da 6
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 5,407
