Introdução
This guide will enable you to remove the antenna in a Motorola Atrix 4G.
O que você precisa
Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
Remove three 5.5 mm T5 Torx screws from the back of the phone.
Lift up the black rubber flap near the SD card slot.
Remove the single 5.5 mm T5 Torx screw beneath the flap.
Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
Lift the tabs located on the bottom of the phone to continue removing the back cover.
Slide an opening tool between the gap from the back of the case to the front.
After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
5 outras pessoas executaram este guia.
