Ir para o conteúdo principal
Motor and Cord Replacement
O que você precisa
  1. Motor and Cord Replacement, The Motor and Cord: passo 1, imagem 1 %32
    • Remove the highlighted screws shown with a Phillips #2 Screwdriver.
  2. Motor and Cord Replacement: passo 2, imagem 1 %32
    • Remove the motor from the motor mounting plate. Pull the motor and cord to the side.
  3. Motor and Cord Replacement: passo 3, imagem 1 %32
    • Use pliers to grip the crimp.
  4. Motor and Cord Replacement: passo 4, imagem 1 %32
    • Open the crimp by pressing it opposite to how the crimp was pressed. Repeat for second crimp.
  5. Motor and Cord Replacement: passo 5, imagem 1 %32
    • Remove the crimps from the wires by pulling them off.
  6. Motor and Cord Replacement: passo 6, imagem 1 %32
    • Untwist the brown and the silver wire by gripping the tip and unwinding them. Do the same for the second wire.
  7. Motor and Cord Replacement: passo 7, imagem 1 %32
    • Separate the cord and motor.
    • Now, depending on whether the cord or the motor was broken, head to the device page to order a new one.
Conclusão
Kamal Taha
Membro desde: 08/27/15
679 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Fall 2015 Membro de USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 42
Duração total: 3,139
