Ir para o conteúdo principal
Moto G6 Plus SIM Card Tray Replacement
O que você precisa
  1. Moto G6 Plus SIM Card Tray Replacement, Remove the SIM card tray: passo 1, imagem 1 %32 Moto G6 Plus SIM Card Tray Replacement, Remove the SIM card tray: passo 1, imagem 2 %32
    • Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
    • Press the tool into the hole to eject the tray.
    • This may require a significant amount of force.
    • The ejection mechanism is deeper in this phone than others and may require a longer SIM card eject tool. If your tool isn't long enough to reach the mechanism, try using an unfolded paperclip instead.
    Pergunte ao FixBot
    Comentar
  2. Moto G6 Plus SIM Card Tray Replacement: passo 2, imagem 1 %32
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Pergunte ao FixBot
    Comentar
Conclusão
Adam O'Camb
Membro desde: 04/11/15
223.603 Reputação
Autoria de 416 guias
2Comentários do guia
Thanks. Your advice on using considerable force worked perfectly!
Piers Spencer - Responder Compartilhar
Mriška na telefon
Eduard Cervenak - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 46
Ao todo: 1,648
