Introdução
Replace a cracked rear glass panel on your Motorola Moto G6 Plus, or remove it for further disassembly.
O que você precisa
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
3 outras pessoas executaram este guia.
3Comentários do guia
Agradecer a todos que fazem o ifixit de grande ajuda para técnicos e principalmente para aqueles iniciantes
Agradecer a todos que fazem o ifixit de grande ajuda para o técnico principalmente para a queles iniciantes
Pueden agregar más elementos de reparación como cambiar centro de carga
