Introdução
If your Motorola Moto G4 is no longer vibrating, replacing the part be necessary. This guide will show the right steps to replacing yourself!
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
Gently twist or pry to open a small gap between the back cover and the body of the phone.
While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
Gently pry straight up to disconnect the battery.
Pull black flap on bottom of motherboard back.
Use tweezers to pop vibration motor off of motherboard.
Uma outra pessoa concluiu este guia.
