Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
If your Motorola Moto G4 is no longer vibrating, replacing the part be necessary. This guide will show the right steps to replacing yourself!
  1. Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port. Gently twist or pry to open a small gap between the back cover and the body of the phone. While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Slide your tool all along the side of the phone to separate more of the clips securing the back cover. Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Keep your tool inserted slightly under the back cover, and slide it around the top corner. If necessary, continue prying around the remaining edges of the phone until the back cover comes free. If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Remove the back cover. To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Push to eject and remove the MicroSD and SIM cards (if installed). Push to eject and remove the MicroSD and SIM cards (if installed). Push to eject and remove the MicroSD and SIM cards (if installed).
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  7. Use a spudger to pry up the rubber cover for the camera flash connector. Use a spudger to pry up the rubber cover for the camera flash connector.
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  8. Remove the rubber cover.
    • Remove the rubber cover.
  9. Use a spudger to disconnect the camera flash connector by prying it straight up. Use a spudger to disconnect the camera flash connector by prying it straight up.
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  10. Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  11. Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  12. Remove the midframe.
    • Remove the midframe.
  13. Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector. Gently pry straight up to disconnect the battery.
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  14. Pull black flap on bottom of motherboard back. Use tweezers to pop vibration motor off of motherboard.
    • Pull black flap on bottom of motherboard back.
    • Use tweezers to pop vibration motor off of motherboard.
Conclusão
Nathan Granger
Membro desde: 12-02-2018
184 Reputação
2 Guias de autoria
Equipe
USF Tampa, Team S15-G3, Boczar Spring 2018 Membro de USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 Membros
9 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 321
